Countersink a hole in a plate
A mounting plate for a limit switch was needed, to be 3D printed, for a little 3018 CNC "engraver."
MoI5beta and calipers were used.
In order to countersink a Hex Button Head Cap Screw, a MoI Cone was used.
The head of the 3mm screw is tapered approximately 45 degrees.
The base diameter of the cone was 6 mm, and the height was 1.5 mm. These dimensions are slightly larger than needed.
Boolean difference with the mounting plate created the countersink.
Export solid plate as STL.
Use Prusa Slicer to create gcode.
Now to do the printing...
