barrel rifleing in MOI3D
11333.4 In reply to 11333.1
Hi Guy, yes Phiro's method using the Twist command is better, it should give high accuracy while at the same time less work to set up since you only need one profile curve.
The Twist command is under Transform > Deform > Twist:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#twist
Thanks Phiro!
