Hi Rusty, I've got a new MoveXYZ command attached.
Instructions on how to install a plug-in here:
https://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
For the first pick this is the same as the regular Move command.
Then for the second pick instead of picking a point with the mouse it will show x,y,z values of the first point and you can change those:
Maybe this should be built in to the regular Transform > Move command with an "XYZ" button that you could press on the target point pick.
