Smooth transition how would you do this?
11326.1
Good day.
I am drawing a kind of car fender ...practicing here.
How can I be able to do a smooth transition from the fender flare to the fender? I created with sweep after I cut it with the pipe script.
Attached a 3dm.
Also if I have a surface with allot of point how can I reduce the points count and how would I select a certain amount of points on a surface instead of starting outside the surface for selection?
Thank you!
EDITED: 14 Jan 2024 by MATADEM
Size: 159.7 KB, Downloaded: 46 times, Dimensions: 2101x1805px
Size: 179 KB, Downloaded: 55 times, Dimensions: 908x446px
