Suggestion save visible object set.
11324.2 In reply to 11324.1
Hi Marc,
> It would be nice to be able to save a snapshot of the visibility of a set of objects.
That's available currently with the "Isolate" function which you trigger by a right click on the Edit > Hide button.
> In the screenshot below, I wanted to be able to isolate the armrest but be able to return to
> this working visibility set without having to show all and hide all the other parts after.
Select the armrest pieces, then right click on Edit > Hide to do "Isolate" which stores an internal snapshot of all current visibility states and then hides the unselected objects leaving only selected objects showing.
Later when you want to return to the pre-isolate state, trigger it again by another right-click on Edit > Hide.
Hope that was what you were looking for,
