Hi Billabong, it can be difficult to remove a hard edge right in the middle of other stuff like that.
Other than filleting, if you can trim away some space around the hard edge then the Construct > Blend command can put in a smooth connecting surface between the open edges. Or the other main approach is making a larger single surface across areas that are supposed to be smooth instead of filling things in piece by piece.
