Shortcut for collapsing palettes for scene browser ?
11316.2 In reply to 11316.1
Hi Sven, the scene browser "inside" mode is primarily intended to be used when you have a large monitor so there is a lot of vertical space available in the side pane.
> Is there a shortcut to collapse all palettes other than scene browser ?
You can set up this on a shortcut key to do that:
script: /* Collapse side pane palettes except scene browser */ var headers = moi.ui.sidePane.document.getElementsByTagName( 'moi:paletteheader' ); for ( var i = 0; i < headers.length; ++i ) { var header = headers[i]; if ( header.id != 'SceneBrowserHeader' ) { var tags = header.getElementsByTagName( 'moi:tabcontainer' ); if ( tags.length == 1 ) { tags[0].activeTab = ''; } } }
