ARC end points tangency
11301.15 In reply to 11301.14
Hi Alex,
> does anyone know if its possible for the cont/arc tool to follow a 3d guide curve as in this image
> I can get it follow only in 1 viewport. any advice once again welcome.
In MoI when you pick points in one of the ortho (Top/Front/Right) views, the points will generally be projected onto the view's grid plane going through the previous picked point.
This is so that when you are drawing in a 2D view you can know that points you get are on that plane.
This restriction is not applied when you pick points in the 3D view, that's why you're seeing a difference when using that view. So if you want to have several points in a draw tool follow a 3D path then pick them in the 3D view.
