Offset Node Issue
11298.5 In reply to 11298.4
Thanks Michael,
The code for Offset node is attached: "offset.js"
I've also attached "main.js" because MO had suggested that the problem may in the difference
between 2 specific versions, for MacOS & for Windows.
I don't know enough about programming to direct you to particular lines in code.
Thanks for looking at this,
