Changing ring size
11290.4 In reply to 11290.3
Hi Gunter, yes that's the spot.
Some space needs to be opened up there by drawing in some cutting lines and using the Edit > Trim command to slice the ends off of the resized part, then select edges and run Construct > Blend to make a smooth blend surface and finally Edit > Join to glue the pieces together.
I've attached a model where I've done that, the steps look like this:
Draw in cutting lines in Front view:
Select resized piece and use the Edit > Trim command to cut it with the lines to open up space like this:
Select edges and run Construct > Blend to fill in the space with a connecting surface:
