Changing ring size
11290.2 In reply to 11290.1
Hi Gunter, is this attached version close to what you're looking for?
I cut the model and also 2 different sized circles and then did Transform > Deform > Flow to deform from the original size to the new size.
You will probably need to cut away a little bit of space around the ends and then put in a blend surface to get it all connected.
