Is there a way to preserve material names?
11286.6 In reply to 11286.5
Hi Alex, the example STEP file does not seem to have any layers set up in it. Those would be some PRESENTATION_LAYER_ASSIGNMENT entries in the file.
So the material names "Color #bdefefff", "Color #c76363ff" and "Color #cdcdeaff" in Pixyz and InstaLOD do not seem to be coming from preserving material names, they are just cooking up that name from the color value.
It is possible to set up a script in MoI to do the same thing. To do that inside MoI go to Options > "Shortcut keys" and add in a new shortcut key and for the command part of the shortcut key put in this:
script: var styles = moi.geometryDatabase.getObjectStyles(); for ( var i = 0; i < styles.length; ++i ) { var style = styles.item(i); style.name = 'Color ' + style.hexcolor.toLowerCase() + 'ff'; }
If you then trigger that shortcut key after loading the step file, the style names in MoI should change from "Level 1", "Level 2", etc... to instead be "Color #cdcdebff", etc... The script just renames all styles to have a name derived from the style's color value.
