how to create this? twist flow?
11279.2 In reply to 11279.1
Hi Matadem, the Blend command can be good for that.
First select the end faces:
And delete them, should look like this:
Then select a pair of edges:
And run the Construct > Blend command to make a blend surface between them:
Repeat for the other 3 pairs (one pair at a time so use the Blend command 4 separate times) and use Edit > Join to glue the surfaces together, see attached .3dm file.
