Hi Zooen,
> Less pleasantly, I've had a few bugs: for example, it's impossible to perform the Boolean
> operation union; whereas it works with the previous version on the same project I'm
> working on.
Can you please send me the .3dm file with the objects that don't boolean union? You can e-mail it to me at moi@moi3d.com if you want to keep it private.
I don't think there have been any changes in boolean related code in this release but it would be good if I could test with your same file to find out for sure.
> I've also had scripts disappear from the drop-down list.
Probably the disappearing scripts were installed in the previous beta's install folder instead of in the AppData folder.
In Windows Explorer if you go to c:\Program Files\MoI 5.0 beta Apr-13-2023\commands do you see the scripts that go missing in there? If so then copy those script files into %AppData%\Moi\commands so they can be found by the new beta.
