Unrelated math help
11259.7 In reply to 11259.5
Ok, so i think i am good to go. Just a check in with you.
I can use 6.55609194538 as the density already fully converted from the 11.34 g.cm-3
From this i can deduce the 2.2 difference (and all future differences)
I will also do a water “volume” test to verify the actual parts volume to verify if diffs are coming from machine and cut.
Thank you Anthony (always nice seeing you in here again)
Thanks Brian. Appreciate your insight.
Burr
