Hi Petr,
> I usually encountered that fillet issue after making a curve boolean
> operation, so I am not sure if it helps directly.
Aha - this seems to be the root problem, I am glad you mentioned it!
It looks like I should be able to tune this up so that curve booleans won't cause an extra segment split at the "seam" point of closed curves.
