Q about curves direction.
11237.1
Hello, All...
I use Moi3D a lot to manually trace some bitmap logo since I think Moi3D has the best tool to do so. But when I export them to CorelDraw (or InkScape) in .DXF, problem occurs when I try to color the objects. After some investigation, I concluded that the problem arise since the exported curves have different directions. I can troubleshoot the matter manually but it often needs a lot of work to go through all curves to determine which direction need to be reversed.
So the question: Is it possible in Moi3D to make ALL the curves in one file have the same direction?
Thank you very much in advance for your help.
Cheers!
EDITED: 29 Oct 2023 by ELANG
