Hi Frederick, curves in MoI are path-like objects - you can't have a single curve that branches like that with 3 lines coming out from a single point.
But like Phiro writes above if you want it to select as one unit you can do that in MoI v5 by making it into a group. You use the "Group" command which is off of the "Objects" section in the scene browser.
