Hi Forum. In the past I've created my panels from scratch using the supplied Front Panel Designer, but now being more comfortable using MoI and learning that Front Designer can import .dxf I'm trying to use MoI to create panel . A video ( https://youtu.be/uSz3E7EjI-Y?si=dxe6QxHbpegrxQxD) explains the process as two steps with a blank panel import and then a cutout import, but this might be dated because I get similar results trying to import a finished panel in a single step. Regardless I end up with cutouts not being in the intended location and I wonder if this is MoI export thing and if so if there is something that I can about it ? Also would like to hear if others are using another service that can take a MoI file directly, etc. I've attached attachments of sample MoI file and some screenshots of the what Front Designer wants to do. Thank you, Sven.
