Hi Paul,
> -- Just realized I can probably make a bunch of lists of the points in
> each object, and then use vectormath.pointsAreEqual to compare points and lists.
I don't think that will work since there isn't currently a way to suck out the points from an object.
I'll see about adding some kind of method that will let you test if an object is a duplicate of another.
