LOCKED or DEEP HIDE
11222.2 In reply to 11222.1
Hi Alex, the problem is that I suspect having 2 different kinds of hiding could lead to confusing situations. Like if you receive a file from someone else you might not know that they used "deep hide" and get surprised that showing all objects did not actually show all the objects.
There are some other options you can use currently with the Edit > Hide button instead of just showing everything.
One is if you right click on Edit > Hide it will trigger an "isolate" function where just the selected objects will remain showing and everything else will hide. But the pre-isolate state is kept in memory and when you trigger the isolate a second time things will return to their pre-isolate state and objects that were originally hidden will remain hidden.
The other thing is if you Ctrl+click on the Edit > Hide button it will trigger a "show subset" function where all hidden objects will be shown and you can select the ones you want to unhide, the ones you don't select will remain hidden after you finish the selection.
