FR : surface ID data (integer) with the .FBX exporter.
11219.2 In reply to 11219.1
Hi PaQ,
> Do you think it would be possible to write, as integer, the Nurbs surface id per polygons when exporting in .FBX ?
It sounds like you mean an ID value that would persist across different modeling sessions?
That doesn't seem like it would be feasible to fit in a single integer value.
Do you have any example FBX files that have this info set on them? Preferably something simple like a box.
The part IDs for LWO export work the same as smoothing groups that are currently written out to OBJ format.
