silhouette points of planar curve
11213.13 In reply to 11213.12
> In my two brief attempts, the Moi Silhouette command attempt in the plane of the curve, did not work.
The Silhouette command only works on surfaces or solids, not on curves.
> I wondered if it uses some different algorithm than the Moi Project command.
Silhouette is pretty different than Project, Silhouette steps along a surface tracing out a curve where surface normals are changing from pointing towards the eye point to pointing away from the eye point.
So for example a surface like this:
Silhouette will generate this:
> Would a more conventional use of the Moi Silhouette command ever produce squashed curves?
No I don't think it would generate squashed curves.
> The Moi Silhouette command seems to be an orthographic projection ?
You tell it which viewport you want to use and it uses whatever projection that view is using. Which will be orthographic if it's the Top/Front/Right view or if it's the 3D view it depends on if Options > View > 3D view projection = "Perspective" or "Parallel".
