Or also another way you could do it is to transform the object so that particular face is flat in one of the regular top/front/right views.
You can do that using the Transform > Orient command, which uses the orientation picker similar to setting a cplane, except with Transform > Orient you use it twice, one to set up the base orientation frame and then to set the target orientation.
