How to export 2D profile of face
11212.4 In reply to 11212.3
Hi Keith, there's a tutorial on setting a construction plane here:
https://www.youtube.com/watch?v=MzthNX0l-Ow&list=PLUilfM8GEmrS3yRLygdFOGJjRZHOzLnkM&index=17&t=122s
But it's pretty straightforward, click the CPlane button in the side pane, it's on the "View" tab.
The command prompt in the upper right of the main window is the spot that MoI tells you what it is expecting you to do next, it will now say "Pick CPlane origin".
Pick a point on the surface you want the view to align to. The orientation picker will align to that surface's normal and then the prompt will say "Adjust axis orientation". At this 2nd step in placing the cplane you can drag one of the orientation picker's axis lines to alter the rotation of the cplane (like if you want the x-axis of the view to point towards a particular point), or if the default rotation is ok you can click the "Done" button or right click in a viewport to accept the default rotation.
At this point the 2D views (Top/Front/Right) will change to be relative to that plane (unless you had unchecked "Orient ortho views" in the cplane command options) and you can export a DXF using one of those now reoriented 2D views.
If you are done working in that cplane you can run View > CPlane again and click the "Reset CPlane" buttton, or also a right click on the View > CPlane button in the side pane is a shortcut for resetting it as well.
Tom Meeks' YouTube channel is probably the most comprehensive tutorial guide for beginners:
https://www.youtube.com/playlist?list=PLUilfM8GEmrS3yRLygdFOGJjRZHOzLnkM
