search in MOI
11187.3 In reply to 11187.1
Hi Ksorks, you can select objects by typed in name by putting in your name in the XYZ point input control in the bottom command bar.
Also you can put focus in that control using the Tab key. You can use wildcard characters * to match anything or ? to match any character.
So for example to select everything with a name that starts with BX, type the Tab key, then type BX* and push Enter. Every object that starts with "BX" will then get selected.
If that's not what you were looking for can you please explain what you need in a bit more detail please.
Thanks, - Michael
