Hi Moi3dFan,
> Is there any way to highlight a row/column of points on a surface? Or Grow/Shrink selection of points?
Sorry no there isn't a way to do either of these things currently.
Surface control point manipulation generally works better with sub-d surfaces instead of NURBS surfaces.
You may want to use a sub-d modeling program to do surface point manipulation type work and then convert the sub-d surface into MoI using SubD > Create > "From file".
