Smoothing surface point in MoI3D
11183.3 In reply to 11183.2
The file's uploaded.
You might try extracting several isoparms except skipping the area that you want smoothed, and then use Construct > Network to build a new surface.
That's the solution too, thanks! I know many ways how to do it by hand. However, I would like to understand if it can be done with scripts or something else.
Manipulating the surface control points directly can have poor results if the surface is not uniformly parameterized.
Let it be left to human conscience, because any tool has limitations. The main thing is to have this possibility, to smooth the points/surface points.
