Understanding control points after isocurve trim ?
11182.1
Hi Forum. The goal is to produce a taper in a series of cylindrical surfaces like that shown in the center of the attached. Easy enough using different ways the simplest I've found being isocurve trim at taper location->scale/resize smaller section->delete surface intended for taper->loft between larger and smaller closed edges of adjacent surfaces. Other ways welcome. I'm curious why I can't get control points for the three distinct surfaces after I add isocurve trims from above sequence. Instead the control points still appear for the bounding box of all three surfaces. It would seem that a closed curve, not a closed edge is necessary for control points. Where can I read more and is there a way to do isocurves that provides control points such that I can better manipulate the tapered section ?
Thank you, Sven
