Face Orientation and Converting 'Joined srf' to Solid in MoI
11162.1
Hi, I'm currently trying to create a design a 1 millimeter thick disc with a gentle curve, into which I am creating an indentation. To create this indentation, I project (or trim) a pattern, extrude it, and perform a Boolean operation. This process sometimes fails, so I'm currently testing with a simplified model.
I've noticed that even when it appears to be correctly processed on MoI, as shown in the attached image, the surface can actually be inverted. Is there a way to check in MoI whether a surface is inverted or not?
I have learned that I can use the 'Flip' command to reverse a face. However, I need a way to identify which faces are reversed.
Furthermore, is it possible to convert a 'Joined srf' like this one into a Solid? If it is possible, I expect that the surface will revert to the correct direction when it is converted to Solid.
I also tried Edit > Join command. But, I get following result.
P.S. In Blender, I confirm the orientation of the faces by selecting the "face orientation" option from the Overlays dropdown.
