The Extract >Tapered dialog box
11137.1
Good morning,
To make this kind of chamfer I use:
the closed curve (1 on the image) >Extrude>Tapered, I give the angle, then the distance. I moved the closed curve and conical extrusion of the box for clarity.
Unless I am mistaken, I noticed that if you enter the distance first, the extrusion is directly validated with the default angle (the default angle or the last one entered). In short, you have to start by entering the angle and then the distance second (or second, the distance manually with the mouse).
Wouldn't it make more sense to put in the dialog the angle above and below the distance. Or at the very least the text at the top of the "Tapered" dialog box should be something like: "Enter the angle then the distance". I wanted to modify it for me in my FrenchStrings.txt file, but I noticed that the text "Pick extrusion point" is used twice, in the 1st box "Extrusion" and the 2nd "Tapered".
EDITED: 18 Aug 2024 by ZOOEN
