Hi Flowgun,
> - curve selection: if some curves are already selected, it selects the rest of curves also.
Updated version below should do this now.
> - Group selection: I use your script that groups selected objects by name (object_0001, object_0002,..).
> Is it possible to make this script loop through named objects? (if one group is selected / nothing is selected)?
Sorry I'm not understanding what you want with this part, can you describe it in some more detail please?
> - point selection: if some points on a curve are selected, it selects the rest.
This is in the updated version below.
> also, I noticed that if more than one object is selected, the script does nothing.
> Maybe it would be useful to select the naked edges of all selected objects
This should also be in the updated version below.
script: var selected_objs = moi.geometryDatabase.getSelectedObjects();
var all_objs = moi.geometryDatabase.getObjects();
var done = false;
/* If some points on a curve are selected, select the rest */
for ( var i = 0; i < all_objs.length; ++i )
var obj = all_objs.item(i);
if ( obj.isCurve && obj.hasSelectedEditPoints )
moi.geometryDatabase.selectAll();
done = true;
break;
if ( !done )
if ( selected_objs.length == 0 )
/* If nothing selected, select all curves */
moi.geometryDatabase.getObjects().getCurves().setProperty( 'selected', true );
else if ( selected_objs.numStandaloneCurves > 0 )
/* If some curves are already selected, select the rest of the curves. */
else if ( selected_objs.numBReps > 0 )
/* If breps are selected, select their naked edges */
selected_objs.setProperty( 'selected', false );
var breps = selected_objs.getBReps();
for ( var i = 0; i < breps.length; ++i )
var brep = breps.item(i);
brep.getNakedEdges().setProperty( 'selected', true );
else if ( selected_objs.length == 1 && selected_objs.numFaces == 1 )
/* 1 face selected, select edges of face */
var face = selected_objs.item(0);
face.selected = false;
face.getEdges().setProperty( 'selected', true );
else if ( selected_objs.numEdges > 0 )
/* If any edges are selected do loop selection */
moi.geometryDatabase.selectLoop();
