Some more pieces to use for the 3 separate scripts:
> - one for dealing with objects: selects last-created objects if nothing is selected, otherwise
> looping through named objects (and it wouldn't matter if they are curves or not)
Nothing selected is detected like this:
var selected_objs = moi.geometryDatabase.getSelectedObjects();
if ( selected_objs.length == 0 )
Selecting last created objects is: moi.geometryDatabase.selectLastCreated();
Stepping through named objects is the chunk of the script above that follows this:
/* If a named object is selected, deselect it and select the next one */
> - one for selecting edges (naked edges or edge loops / boundaries)
Selecting naked edges is the part of the script above with:
/* If surfaces are selected, select their naked edges */
Selecting edges of a face is this part:
/* 1 face selected, select edges of face */
Loop selection is this part:
/* If any edges are selected do loop selection */
> - one to select curves: it would loop through selecting open curves, closed curves, and all curves. even if nothing is selected.
Selecting all curves is the part marked with this:
/* If nothing selected, select all curves */
to select just open or closed curves, that would be like this:
var curves = moi.geometryDatabase.getObjects().getCurves();
for ( var i = 0; i < curves.length; ++i )
var crv = curves.item(i);
if ( crv.isClosed )
crv.selected = true;
