Single script to select different things
11127.15 In reply to 11127.13
So if you wanted to give the select naked edges part priority over the named object handling, take this piece:
	else if ( selected_objs.numBReps > 0 )
		/* If surfaces are selected, select their naked edges */
		selected_objs.setProperty( 'selected', false );
		var breps = selected_objs.getBReps();
		for ( var i = 0; i < breps.length; ++i )
			var brep = breps.item(i);
			brep.getNakedEdges().setProperty( 'selected', true );
Remove the "else" at the start there and insert a done = true; inside it, and move it above the named object handling which starts at this comment:
/* If a named object is selected, deselect it and select the next one */
And if you want it to do naked edges if only one object is selected change this:
to this:
if ( selected_objs.numBReps == 1 )
But like I mentioned, if you do that then if you have a solid that is a named object and it is the only object with that name, the "step to next named object" is going to get stuck on it.
= Michael
