Best Mouse for Moi3D
11122.5
I have tried many mice, but my recommendation is based on my personal experience because I have relatively large hands, and they get strained very fast Working on comp. I use a trackball mouse and a trackpad to protect my hands; that is the same as connecting a mouse to a laptop and using a mouse with its trackpad. I have been working that way for years with every 3d software I use, and you can combine movements.
I used Elecom huge Trackball. It Works excellent for 3d modeling But is Noisy at clicks; it looks cheap but is very comfortable and responsive, with three years lifespan.
MX Master 3s and MX Vertical are comfortable mice but function with Bluetooth.
MX Master3s is a Little bit tricky to use along with a trackpad in MOI, but it is possible with the correct setup, but it works perfectly with just the mouse on Moi (Current Mouse)
But if you can go to a physical store that sells electronics and try it in your hand is my recommendation, and then buy online if you want; I preferred in this way because I give importance to ergonomics, but even that is personal.
I hope this help. I hope you find to mouse that work best for you.
