.hidden property and groups (scripting)
11120.4 In reply to 11120.2
Re:
> if it did try to do the same thing it could have some potentially
> strange effects. Like if you set .hidden = false on a child object, it
> would probably be weird for hidden = false to be set on parent groups
> which would cause objects in other sibling sub trees of the group to get
> hidden.
At the end you mean "shown", like hidden = false, right?
That basically describes the problem I was having: I wanted to do something like in a scene where everything is hidden just show one face of a solid that's in a group with some other solids without showing any of the other faces of that solid or any of the other solids. Like how if I name a face then I can click in the eye column of the browser next to that name and show just that face.
Re:
> obj.hidden = false;
> var toplevel = obj.getTopLevelParent();
> if ( toplevel.isGroup )
> toplevel.hidden = false;
Showing the top-level parent group causes everything in that group to get shown, which is not what I want.
Here's what I ended up doing, but it seems like I'm maybe not understanding something and am also reinventing the wheel since I'm basically trying to get the same behavior as when setting object visibility with the browser.
Two things that caused some trouble are:
  1. Setting hidden = true on a non-group object fails to set hidden = true on sub-objects
  2. .getSubObjects() operates recursively rather than just giving immediate children
I also tried using .getNextNode(), but since it enters a group rather than returning it, it causes the same trouble as .getSubObjects().
var obj = moi.geometryDatabase.findObject('{874ac4db-5919-4fbd-9bbc-2c9604332b65}'); // face
// var obj = moi.geometryDatabase.findObject('{4e824df8-dbb6-4c4a-a9b7-40c52acaab6e}'); // box
// var obj = moi.geometryDatabase.findObject('{7ff98c04-d959-4567-ada2-93a8ecbf8128}'); // Group05
showObj(obj);
// sets hidden = false on obj and its parents recursively, but avoids changing .hidden on siblings
function showObj(obj) {
    var parentObj = obj.getParentObject();
    if obj is a child of hidden non-Group object
    need to set hidden = true on all sub-objects of that hidden parent
    var firstHiddenParentInArray = getHiddenParent(obj);
    if (firstHiddenParentInArray.length === 1) {
        var firstHiddenParent = firstHiddenParentInArray[0];
        var subObjList = firstHiddenParent.getSubObjects();
        subObjList.setProperty('hidden', true);
    // record state of siblings
    var siblingList = getSiblings(obj);
    var siblingStateDict = {};
    for (var i = 0; i < siblingList.length; ++i) {
        var sibling = siblingList.item(i);
        siblingStateDict[sibling.id] = sibling.hidden;
    obj.hidden = false;
    if (parentObj != null) {
        showObj(parentObj);
            sibling.hidden = siblingStateDict[sibling.id];
// returns array containing the top-most *non-Group* parent of obj that is hidden
// if hidden = false on all non-Group parents then returns empty array
function getHiddenParent(obj) {
    var hiddenParentInArray = [];
    doGetIsInHiddenObject(obj, hiddenParentInArray);
    return hiddenParentInArray;
    function doGetIsInHiddenObject(obj, hiddenParentInArray) {
        var parent;
        if (obj != null) {
            parent = obj.getParentObject();
        } else {
            parent = null;
        if (
            parent != null &&
            parent.hidden === true &&
            parent.isGroup === false
            hiddenParentInArray[0] = parent;
        if (parent != null) {
            doGetIsInHiddenObject(parent, hiddenParentInArray);
// returns an objectList of the immediate siblings of obj
// in other words, all objects that have the same immediate parent as obj
// excludes obj itself
// excludes curveSegments since they aren't targetable in the viewports
function getSiblings(obj) {
    if (obj.isCurveSegment) {
        moi.ui.alert('attempted to get sibling of a curve segment in getSiblings()');
    var immediateSiblingsList = moi.geometryDatabase.createObjectList();
        var siblingsList = parentObj.getSubObjects();
        for (var i = 0; i < siblingsList.length; ++i) {
            var sibling = siblingsList.item(i);
            var siblingParent = sibling.getParentObject();
            if (
                sibling.isCurveSegment === false &&
                sibling.id != obj.id &&
                siblingParent != null &&
                // getSubobjects() is recursive so need to verify that it's the same parent and not a parent
                // somewhere else in the heirarchy
                siblingParent.id === parentObj.id
                immediateSiblingsList.addObject(sibling);
    return immediateSiblingsList;
- Peer
