Sweep Pipe Matrix Intersections?
11116.7
Hello,
Thanks for all of the suggestions. The larger issue I'm running into at the moment is stacking the pipes into a matrix, e.g. 3x3. The rows stay pretty good in terms of clearance but the pipe stack rows end up intersecting with one another badly which is a little puzzling to me unless this just has to do with me using the wrong tool to keep things separated. Is it fair to say the blend curve tool will not keep the center rail curves equidistant from one another so the swept circle profiles will intersect? Thanks.
