Sweep Pipe Matrix Intersections?
11116.4 In reply to 11116.3
Hi OSTexo, the Blend function just doesn't have anything in it that tries to make a result that is equidistant from some other curve.
To keep the pipes in the same relationship to each other throughout, it would probably be good to use just one single path instead of 3 different paths.
One way to do that is to use the Transform > Deform > Flow command.
Start by making 3 cylinders with a line running down the middle like this, with just one path curve set up, like this:
Select just the cylinders and not the center line. Then run Transform > Deform > Flow. At the prompt to select the base curve now select the center line and for the target curve select the path, and set the "Stretch" option in the Flow command options:
To do it with sweep you'd want to use just the same one rail for all 3 sweeps, but it's a bit tricky to do that because when the profile is outside of the bounding box around the rails it will engage "auto place" mode where it moves the profile to the start point of the rail. So you would kind of need an option to turn off auto place mode to do it that way, currently there is not a separate option for that.
