getOpenFileName and getSaveFileName
11078.2 In reply to 11078.1
Hi peer, yes moi.filesystem.getOpenFileName() and moi.filesystem.getSaveFileName() each can take 3 function arguments:
Arg 0 - required - string for dialog title
Arg 1 - required - string for file extension filters:
// The filter string has entries separated by the pipe | character, with
// the entries in pairs with a label first and then a filter next, for example:
// 'Point files (*.txt, *.xyz, *.csv)|*.txt;*.xyz;*.csv|All files (*.*)|*.*'
Arg2 - optional - string for filename to initialize with.
You should be able to send in a directory path for the initialize filename arg.
