Hi rhinouser141,
See .3dm attached
Another method is Construct > Network where a net of curves is drawn first:
And then they are all selected as the input to Construct > Network:
And finally maybe the most direct method is to use Construct > Blend after first drawing a little stub of a plane at the G0 side:
One way of drawing the stubs is to do Construct > Extrude on an edge curve of the large plane, click Set Dir, and then pick 2 points to set the extrusion direction. A temporary construction line might be useful here.
- Peer
