Is there a way to chamfer this? parallel lines?
11065.2 In reply to 11065.1
Hi Matadem,
> I am working on something here but I cannot chamfer this...file attached. bot sides.
It seems to be working ok for me over here. What distance are you using?
For example here with 0.2mm:
> Also if I have a line at a certain angle and I want to make another line a distance away
> is there a way to draw at the same angle? parallel?
Transform > Copy or Construct > Offset can be good for creating a new parallel line somewhere else.
You can also use it in drawing by making a construction line. You do that by pressing and holding down the mouse button and dragging with the mouse button still held down while you are in a drawing command. After you have placed a construction line a little marker will appear and if you click and hold on that a menu will pop up and allow you to do some other things like relocate the construction line somewhere else.
Here's what it it looks like:
