V5 beta Apr-13-2023 available now
11056.53 In reply to 11056.51
Hi blackboard,
> Add one more parameter to trim "Trim from surfaces\solids"
The Edit > Trim command already supports trimming using surfaces or solid as the cutting objects.
You don't need to set any parameter to do it, when the Trim command asks you to select cutting objects just select your solid or surface then.
