Hi Wm,
> I'm trying to understand why in beta Version 5b...when you click Done after Deform-Flow,
> the Flow process just starts calculating again. In Version 4 the command stops immediately.
> That is confusing to me. I'm experimenting with your Bell Flat_flow.3dm file.
The different behavior from v4 looks like is caused by the introduction of Groups in v5, there is some processing that happens to support groups which as a side effect triggers a final update even if there was a previous update.
> Is that a bug or is that just the way it works?
I guess it's a bug since the final update for processing groups shouldn't need to be done if there are not any groups being transformed.
It's not a particularly harmful bug though, it may run the risk of messing up group handling to fiddle with it.
Support for groups involved some pretty big changes throughout the system.
