V5 beta Apr-13-2023 available now
11056.172 In reply to 11056.171
Hi Lewis,
> 1. it just dumps _v5 file, no save as or progress bar (weird but ok i can live with that).
Right, that's because it takes a lot of work to make functionality like progress bars, this is just a bare bones utility program that isn't focused on having any UI.
> 2. It's not loaded completely (I'm trying to convert chair 3d model and i got only frame
> but soft cushioning is not visible in Moi after conversion). So basically moi is not opening
> it correctly after conversion or conversion is bad.
Most likely the soft cushioning is some kind of object type that MoI does not support like a polygon mesh object.
Moi only reads NURBS and annotation type objects from .3dm files, not every kind of thing that Rhino can store in them.
> I can send you model if you wish to test ?
Sure you can e-mail it to me at moi@moi3d.com, you may need to use a file sharing service if it's very large.
But it's very likely that it's polygon mesh data that MoI is not designed to work on.
