Hi wayne,
> Not sure if this event has been reviewed:
> Changing image properties with proportions sizes off, the image will revert back to original ratio when dragging the anchor size.
Yes, dragging always uses the image's inherent aspect ratio. If you want to change the aspect ratio permanently you can edit the image in an image processing program to your desired new size.
