Hi marzRX, you might try the control panel method for setting associations, the 2nd method mentioned here:
https://fileinfo.com/help/windows_7_file_associations
Another thing you can try is to uninstall v4 and then re-install it, the installer should set the file associations.
There is also a new v5 beta that you can get at https://moi3d.com/beta.htm .
If nothing else works then the place to set it in the registry is under:
HKEY_CLASSES_ROOT\MoI.3DMFile.1\shell\open\command
which will have a value like this:
"C:\Program Files\MoI 5.0 beta Apr-8-2023\moi.exe" "%1"
You'd change that path to the v4 moi.exe
