Can viewport move be disabled?
11053.1
Hello all,
I was wondering if there was a way to disable the "click and move" functionality in Moi. I have a couple of co-workers that are learning Moi but they prefer to use
a Wacom tablet over a mouse and a reoccurring problem is when they click to select the object, they accidently end up nudging the object out of location in doing so.
Its becoming a problem because its starting to discourage them from using Moi and I would like for it to be a pleasant experience.
I though by disabling the edit frame in the options that this would disable the viewport move, but unfortunately you can still move an object when the edit frame is off.
Its not that I want to lock the object as I still want to be able to select the object. I would just rather any transform operations that occur are explicitly from the tools in the transform tab.
Cheers!
