fillet method that makes aligned tangent edges
11045.4 In reply to 11045.1
Hi Peer, that kind of mismatching is normal for Mechanical CAD rolling ball type fillets.
It's because the width of the fillet depends on the angle between 2 surfaces.
If the angle is shallow between 2 surfaces, the fillet will be smaller in width, like this:
As the angle between the surfaces increases, the fillet, using the same radius, will be wider like this:
The thing that is equal between them is that they are both pieces of the same radius circle, they just have different lengths along the circle:
So in the case that you show, the angles between these pairs of surfaces are different:
Since the angles are different, the fillet surfaces' width will be different and so if they are directly connected with each other they will have the result you show.
Usually the way to get the fillets to align nicely is to have all the edges that share a common point to be filleted instead of only some of them. That then allows for juncture patches to be made where the fillets come together instead of having fillet surfaces directly running into each other:
