Hi blackboard,
> Hello,thanks for new update.what will come out next?
Next there will probably still be more fixes for the fillet integration.
> will moi3d have a pull/push function like in fusion or similar like in plasticity.
Yes, that's the "Direct Modeling" functionality that I was mentioning earlier.
There is some push/pull like functionality already working though, if you select a face object then you can use the Extrude command to do a push/pull like action where it automatically booleans the extrusion with the main body.
http://moi3d.com/forum/index.php?webtag=MOI&msg=6790.3
> When will the next beta release be?
There will probably be new bug fix releases every 1 to 2 weeks while tuning the ACIS integration.
