V5 beta Apr-8-2023 available now
11043.13 In reply to 11043.11
> Alas no same result!
> In Solid++ or Acis !
Hi Pilou, here are the steps I'm following.
Step 1 - load your file kub05.3dm using the Apr-8-2023 v5 beta.
Looks like this:
Then i selected the edge you indicated:
And then I ran the Fillet command and put in radius = 3, I get the glitch that you saw:
After the fillet command has been completed if I now save to a .3dm file and reload it, the glitch is gone. Looks like this:
Do you see different results with these same steps?
